Intel EtherExpress (8255x) driver?
Mike Panetta ahuitzot at mindspring.com
Fri Jun 28 04:23:21 UTC 2002
I would be intrested in having a copy of the driver as well.  I have a
board with 2 of these on it, and this may make it worth while for me to
play with RTEMS on this board.  Anyone used RTEMS in a router yet?  Are
there facilities similar to Linux's IP-Tables NAT setup available in
RTEMS?
Thanks,
Mike
On Thu, 2002-06-27 at 12:49, Thomas Doerfler wrote:
> Hello Eric,
> I ported it to RTEMS 6 months ago. I am not yet
> sure, whether it works correctly, I had some
> strange effects when I ran it last time, so this
> is work in progress. Nevertheless I will send the
> current code as separate eMail, have fun with it!
> (By the way, I ran together with an AMD Elan520
> (i586 architecture).
> wkr,
> 	Thomas Doerfler.
> > Has anyone got the FreeBSD network driver for the Intel 8255[789] (Intel
> > EtherExpress Pro/100B PCI Fast Ethernet) working with RTEMS?  I've got a
> > PC-104 card with one of these devices and it would certainly save a lot
> > of time if I didn't have to port the driver myself.
> > Thanks,
> > Eric Norum <eric.norum at usask.ca>
> > Department of Electrical Engineering
> > University of Saskatchewan
> > Saskatoon, Canada.
> > Phone: (306) 966-5394   FAX:   (306) 966-5407
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_key.htm
