Ada's SELECT in C
Pattara Kiatisevi
pkiatisevi at student.ei.uni-stuttgart.de
Fri Mar 1 16:07:06 UTC 2002
Ok, I get it worked with pthread now, code is much longer and more
complex). But hmm, now I can't find the libpthread.a for
SPARC/LEON....does it exist?
Thanks,
Pattara
On Thu, 28 Feb 2002, Pattara Kiatisevi wrote:
> Hi,
> I have a not-so-directly-involved-with-RTEMS question but just ask for
> conceptual idea. As I learnt the syntax "SELECT" in ADA and now have to
> program with pthread on RTEMS. Anybody knows how to translate the
> following snippet of psuedo code into pthread's concept?
> buffer_t buffer[xxx];
> task Player;
> main {
> int currentbuffer = 0;
> Create and run Player task;
> while(input not EOF) {
> decode_music_from_input_to(buffer[currentbuffer]);
> Play.goPlay(currentbuffer); // Block if Player is still busy
> Change value of currentbuffer to whatever e.g. +=1
> play.stop();
> Player {
> forever {
> Select
> Accept Stop() : exit ;
> Accept Goplay(currentbuffer) : // only this line in rendezvous
> Outputsound(buffer[currentbuffer]);
> //this output sound could block
> End Select;
> Thank you for all the answer(s),
> Pattara
> Please avoid sending me Word or PowerPoint attachments.
> See http://www.fsf.org/philosophy/no-word-attachments.html
> Ott Pattara Kiatisevi T L W G
> M.Sc. INFOTECH Student, Stuttgart, Germany http://linux.thai.net/
