linux-posix
Fri Mar 8 19:10:49 UTC 2002
"Aaron J. Grier" wrote:
> On Thu, Mar 07, 2002 at 08:10:47PM +0100, Peter Mueller wrote:
> > for a demo I like to "connect" a rtems application running on Linux
> > with a pure Linux application. How can I do that? Is there a way to
> > communicate between the rtems app and the pure linux app?
> you could use a pipe.  microwindows demo uses this to communicate
> between a client running in RTEMS and a server running on linux.
> I'm sure there are more clever ways, but I have seen this method
> demonstrated and working.  ;)
I've used the psim BSP to pass data via shared memory with a Linux
application.  I added shared memory and semaphore devices to
psim in order to do this and they are included in the standard
powerpc-rtems-gdb RPMs.
As I recall, the UNIX port uses shared memory for the mptests so
it also has support for accessing shared memory.  Same trick
is already in place there.
>   Aaron J. Grier  |   Frye Electronics, Tigard, OR   |  aaron at frye.com
>      "In a few thousand years people will be scratching their heads
>        wondering how on earth the first computer was invented and
>           bootstrapped without a prior computer to do it with."
>                     --  Chris Malcolm, on comp.arch
