Network driver for SMSC LAN91C96 (91C94)
Jonas Moberg jonas.moberg at solidsoftware.net
Tue Mar 12 07:12:43 UTC 2002
Thanks Ian,
Yes, it would be very helpfull if I could have a look at your BSP port as
well as the SMC91C111
driver (when available).
It is likely that our final board will share your design using the 5307 and
SMC91C111.
Our current design and existing boards are using a 5206e and the 91C96.
I beleive the '111 and '96 are more or less code compatible (with
variantions).
So please let me know of any progress and hopefully and can contribute with
something back
to your side.
I am also primarly using Cygwin on W2000 and have (for no particular reason)
started to work
on the 4.5.1-pre3 release and got everything to build properly (including
Davids BSP).
Have seen problems during the bootstrap (autoconf) stage that script tries
to find out if the cross
compier (m68k-...) is a cross compiler by executing the executable.
Unfortunately the Cygwin
(Win) shell executes the file (actually a m68k target) and looks up.
Also built the latest (experimental snapshot) versions of tools and had
problems with preprocessor
header include in the tools directory itself - it seems to include the file
as shown from the error
output but the file is never read. Have not cracked this problem yet and
have resumed work
with the tool package that comes with the RTEMS 4.5.1 release.
Regards
Jonas Moberg
----- Original Message -----
To: "Jonas Moberg" <jonas.moberg at solidsoftware.net>
Cc: <rtems-users at oarcorp.com>
Sent: Tuesday, March 12, 2002 2:54 AM
Subject: Re: Network driver for SMSC LAN91C96 (91C94)
> Hi Jonas,
> I am just starting work on creating a network driver for the SMC91C111
> for our Coldfire 5307 RTEMS design.  It is is *very* early stages of
> development at the moment.
> We are currently using release 4.5.0 and we did some work to port David
> Fiddes 5307 BSP up to 4.5.0.  We do not have one of these boards
> however, and so could not test it other than the fact that it builds.
> We then created our own custom 5307 BSP from the other one and have had
> no problems, as it only really used the internal serial port and the
> internal timer.  We did not take the network code over.
> Our development environment is Cygwin, and if you would like a copy of
> the ported BSP, just let me know.
> I will try to let you know when I have the network driver running.
> Talk to you soon,
> Ian Caddy
> Jonas Moberg wrote:
> > Hi, I am new to this list. We are developing integrated security
> > systems for buildings etc.Currently working in the feasability stage
> > with a ColdFire design and a 91C96LAN controller. Has anybody written
> > (ported) a 91C9x network driver to RTEMS? Is there any additional work
> > on David Fiddes ColdFire BSP work from '98?And if so - Where can it be
> > found? Regards Jonas Moberg
> ianc at microsol.iinet.net.au
> Microsol (Aust) Pty Ltd
> Phone: (+61) 08 9473 6600
> Fax:   (+61) 08 9473 6699
