cygwin running forign exe was Re: Network driver for SMSC LAN91C96 (91C94)
Wed Mar 13 12:21:29 UTC 2002
Jonas Moberg wrote:
> Thanks Ian,
> Yes, it would be very helpfull if I could have a look at your BSP port as
> well as the SMC91C111
> driver (when available).
I would like to see this driver in the RTEMS tree and hopefully
implemented
in a libchip style so other BSPs can use it as well.
> It is likely that our final board will share your design using the 5307 and
> SMC91C111.
> Our current design and existing boards are using a 5206e and the 91C96.
> I beleive the '111 and '96 are more or less code compatible (with
> variantions).
> So please let me know of any progress and hopefully and can contribute with
> something back
> to your side.
> I am also primarly using Cygwin on W2000 and have (for no particular reason)
> started to work
> on the 4.5.1-pre3 release and got everything to build properly (including
> Davids BSP).
> Have seen problems during the bootstrap (autoconf) stage that script tries
> to find out if the cross
> compier (m68k-...) is a cross compiler by executing the executable.
> Unfortunately the Cygwin
> (Win) shell executes the file (actually a m68k target) and looks up.
I don't have the instructions handy but this is in the mailing list
archives.  There is a registry setting to make NT/Win2K do the right
thing and not run it.
> Also built the latest (experimental snapshot) versions of tools and had
> problems with preprocessor
> header include in the tools directory itself - it seems to include the file
> as shown from the error
> output but the file is never read. Have not cracked this problem yet and
> have resumed work
> with the tool package that comes with the RTEMS 4.5.1 release.
The snapshot tools work with snapshots, release tools with release.
There was a re-org of some POSIX .h files between RTEMS and newlib so
we shared as much as possible with other targets.  This occurred after
4.5
> Regards
> Jonas Moberg
> ----- Original Message -----
> From: "Ian Caddy" <ianc at microsol.iinet.net.au>
> To: "Jonas Moberg" <jonas.moberg at solidsoftware.net>
> Cc: <rtems-users at oarcorp.com>
> Sent: Tuesday, March 12, 2002 2:54 AM
> Subject: Re: Network driver for SMSC LAN91C96 (91C94)
> > Hi Jonas,
> > I am just starting work on creating a network driver for the SMC91C111
> > for our Coldfire 5307 RTEMS design.  It is is *very* early stages of
> > development at the moment.
> > We are currently using release 4.5.0 and we did some work to port David
> > Fiddes 5307 BSP up to 4.5.0.  We do not have one of these boards
> > however, and so could not test it other than the fact that it builds.
> > We then created our own custom 5307 BSP from the other one and have had
> > no problems, as it only really used the internal serial port and the
> > internal timer.  We did not take the network code over.
> > Our development environment is Cygwin, and if you would like a copy of
> > the ported BSP, just let me know.
> > I will try to let you know when I have the network driver running.
> > Talk to you soon,
> > Ian Caddy
> > Jonas Moberg wrote:
> > > Hi, I am new to this list. We are developing integrated security
> > > systems for buildings etc.Currently working in the feasability stage
> > > with a ColdFire design and a 91C96LAN controller. Has anybody written
> > > (ported) a 91C9x network driver to RTEMS? Is there any additional work
> > > on David Fiddes ColdFire BSP work from '98?And if so - Where can it be
> > > found? Regards Jonas Moberg
> > Microsol (Aust) Pty Ltd
> > Phone: (+61) 08 9473 6600
> > Fax:   (+61) 08 9473 6699
