_init _fini
Gerald Needell
jerry.needell at unh.edu
Wed Mar 13 18:40:06 UTC 2002
What is the purpose of the code in boot_card:
#ifdef USE_INIT_FINI
atexit(_fini);
_init();
#endif
For the ERC32 USE_INIT_FINI is defined. It looks to have something to do
with c++ constrictors, but I built the system with --disable_cxx. Any
attempt to trace code throght _init causes the system to crash. If trace
into _init, the stack pointer gets set to the rdb_mon area and the
return causes the system to halt. If I set break point just after the
return from _init, all seems fine. What is this code doing?
- Jerry
_______________________________________________________________________
Jerry Needell | Internet: jerry.needell at unh.edu
Space Science Center/Morse Hall | Voice: (603) 862 2732
University Of New Hampshire | FAX: (603) 862 0311
Durham, NH 03824 |
