preemption question
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Thu Mar 14 15:42:46 UTC 2002
 > Hi,
 > if :
 > long c1, c2, c3;
 > rtems_task t1(
 >   rtems_task_argument argument
 >     c1=0;
 >     while(1){
 >         c1++;
 > rtems_task t2(
 >     c2=0;
 >     while(1){
 >         c2++;
 > rtems_task t3(
 >     c3=0;
 >     while(1){
 >         c3++;
 > and  tasks mode = RTEMS_PREEMPT + RTEMS_NO_TIMESLICE, with egal priority.
 > Which has to be the result after n second?
 > c1 >0
 > c2 =0
 > c3 =0
 > or
 > c1 >0
 > c2 >0
 > c3 >0
Assuming a short enough runtime so the vars don't roll over, the first
scenario is what you should see.  If you enable timeslicing, then
scenario #2 should appear.  Be sure to make your variables above of
type volatile... ;)
Gregm
