librdbg patch
Till Straumann
strauman at SLAC.Stanford.EDU
Tue Mar 19 21:33:20 UTC 2002
Hi
I found that
librdbg/src/powerpc/new_exception_processing/remdeb_svc.c
was not made correctly (ss-20020301):
- Makefile had SED not set
- extra semicolon in Makefile.am
The attached patch fixes these issues.
Regards
-- Till
Index: configure.ac
RCS file: /afs/slac/g/spear/cvsrep/rtems/src/c/src/librdbg/configure.ac,v
retrieving revision 1.1.1.1
diff -c -r1.1.1.1 configure.ac
*** configure.ac 2001/12/14 22:54:16 1.1.1.1
--- configure.ac 2002/03/19 20:54:55
*** 27,32 ****
--- 27,33 ----
AC_CHECK_PROG(RPCGEN,rpcgen,rpcgen,no)
AC_PROG_AWK
+ AC_CHECK_PROG(SED,sed,sed,no)
if test "$RPCGEN" = "no"; then
AC_MSG_WARN([** missing rpcgen, required to build librdbg **])
*** 34,39 ****
--- 35,44 ----
fi
if test "$AWK" = "no"; then
AC_MSG_WARN([** missing awk, required to build librdbg **])
+ rpctools="no"
+ fi
+ if test "$SED" = "no"; then
+ AC_MSG_WARN([** missing sed, required to build librdbg **])
rpctools="no"
fi
Index: src/powerpc/new_exception_processing/.cvsignore
RCS file: /afs/slac/g/spear/cvsrep/rtems/src/c/src/librdbg/src/powerpc/new_exception_processing/.cvsignore,v
diff -c -r1.1.1.1 .cvsignore
*** src/powerpc/new_exception_processing/.cvsignore 2001/12/14 22:54:21 1.1.1.1
--- src/powerpc/new_exception_processing/.cvsignore 2002/03/19 21:26:14
*** 1,2 ****
--- 1,4 ----
Makefile
Makefile.in
+ remdeb_svc.c
+ remdeb_xdr.c
Index: src/powerpc/new_exception_processing/Makefile.am
RCS file: /afs/slac/g/spear/cvsrep/rtems/src/c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am,v
retrieving revision 1.1.1.2
diff -c -r1.1.1.2 Makefile.am
*** src/powerpc/new_exception_processing/Makefile.am 2002/03/07 01:55:09 1.1.1.2
--- src/powerpc/new_exception_processing/Makefile.am 2002/03/19 20:50:18
*** 71,77 ****
-o powerpc/new_exception_processing/tmpSvc.c remdeb.x; \
$(AWK) -f ./awk.svc THEPROG="remdeb.h" powerpc/new_exception_processing/tmpSvc.c \
> powerpc/new_exception_processing/remdeb_svc.c; \
! $(SED) -e 's/fprintf.*,/printf(/' powerpc/new_exception_processing/remdeb_svc.c; > powerpc/new_exception_processing/remdeb_svc.tmp; \
mv powerpc/new_exception_processing/remdeb_svc.tmp powerpc/new_exception_processing/remdeb_svc.c; \
rm -f powerpc/new_exception_processing/tmpSvc.c )
endif
--- 71,77 ----
! $(SED) -e 's/fprintf.*,/printf(/' powerpc/new_exception_processing/remdeb_svc.c > powerpc/new_exception_processing/remdeb_svc.tmp; \
endif
