rtems image crashes while booting on mcp750
Deepak Bansal bansal at nms.lcs.mit.edu
Sun Mar 24 15:08:30 UTC 2002
Hi,
I have compiled and built rtems application images (including hello.exe)
for mcp750. After downloading the image (hello.exe) on the board (using
nob), it uncompresses the image, checks openpic driver and then crashes
with exception 3.
RTEMS 4.x/PPC load: Uncompressing the kernel...
Kernel at 0x00000000, size=0x692b0Initrd at 0x00000000, size=0x0
Residual data at 0x0006a000Command line at 0x00071000doneNow booting...
Welcome to RTEMS RELEASE rtems-ss-20010525(PowerPC/PowerPC 750/mcp750) on
Mesquite cPCI (MCP750)
-----------------------------------------OpenPIC found at c1000000.
OpenPIC Version ? (2 CPUs and 17 IRQ sources) at c1000000
OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 2
OpenPIC timer frequency is 8333848 Hz
exception handler called for exception 3
I get same error with other sample applications also. I think it is trying
to initialize console driver... How can I get rid of this exception and
get the sample application to boot?
Thanks in advance for the help.
-Deepak
