scan with timeout
Stan
zylog at club-internet.fr
Wed Mar 27 09:36:53 UTC 2002
Hi,
I should like all input operation (read...scan...) return on timeout.
What are best way for that ?
This code you seem good ?
In fact, the first call to the function scan return on timeout, but not the
following.
An idea?
/* transfer character from the buffer */
char inbyte(int minor, int* timeout) {
register char a;
register int length;
while ((char *)(((int)rcv[minor].in+1) & ((int)BUFFER_LENGTH-1))==
rcv[minor].out){
if(*timeout) (*timeout)--; else return '\0';
rtems_task_wake_after(1);
a=*(char *)((int)rcv[minor].offset+(int)rcv[minor].out);
rcv[minor].out= (char *)(((int)rcv[minor].out+1) &
((int)BUFFER_LENGTH-1));
length = (BUFFER_LENGTH -1) & (
( ((int)rcv[minor].out <= (int)rcv[minor].in) ? 0 : BUFFER_LENGTH) -
(int)rcv[minor].out
+ (int)rcv[minor].in + 1);
if ((params[minor].mode & MODE_RTSCTS) && length < RTS_START_SIZE)
StartRemoteTx(minor);
return (a);
rtems_device_driver console_read(
rtems_device_major_number major,
rtems_device_minor_number minor,
void *arg
rtems_libio_rw_args_t *rw_args;
char *buffer;
int maximum;
int count = 0;
volatile int timeout;
rw_args = (rtems_libio_rw_args_t *) arg;
buffer = rw_args->buffer;
maximum = rw_args->count;
for (count = 0; count < maximum; count++) {
timeout = 100*60; /* 100*60*5 = 5 minutes */
buffer[ count ] = (char) inbyte(minor, &timeout);
if(timeout==0) break;
if ( params[minor].mode & MODE_CANON && (buffer[ count ] == '\n' ||
buffer[ count ] == '\r')){
if ( params[minor].mode & MODE_ADD_LF ) buffer[ count] = '\n';
count++;
break;
rw_args->bytes_moved = count;
return (count >= 0) ? RTEMS_SUCCESSFUL : RTEMS_UNSATISFIED;
thanks.
Stan .
