Debug vs. Release compilations of application
Brett Swimley brett.swimley at aedinc.net
Wed Mar 27 17:29:35 UTC 2002
Hello,
I'm trying to determine the "correct" way to build debug vs. release
versions of my application. I'm using rtems-ss-20011005.
My /make/custom/bsp.cfg file specifies:
CFLAGS_OPTIMIZE_V = -O4 -fomit_frame_pointer
My makefile is based upon the example makefile found in the
hello_world_c-4.5.0.tgz file on the oar ftp site.
I'm assuming:
make debug:
will build my application sources with CFLAGS += CFLAGS_DEBUG_V (which I
currently do not have defined)
make all
will build my application sources with CFLAGS += CFLAGS_OPTIMIZE_V (as
defined above).
It appears that these flags are not applied when I perform a make all.
Is there a preferred method (using automake, etc.) of creating a makefile
for my application build?
Regards,
Brett Swimley
Sr. Design Engineer
Advanced Electronic Designs, Inc.
ph: 406-585-8892
fax: 406-585-8893
www.aedinc.net
