linux-posix
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Mar 10 00:05:33 UTC 2002
Peter Mueller wrote:
> Hi Aaron, hi Joel,
> do I have to consider anything special configuring rtems using the ways you suggested?
> Shared Memory: I assume that this requires MP support enabled?
Yes since right now, that is all that uses it.
> Microwindows: ?
Nothing special that I know of. Rosimildo is the keeper of that.
Updates, etc new howtos are welcomed. :)
> Peter
> On Fri, 08 Mar 2002 13:10:49 -0600
> Joel Sherrill <joel.sherrill at OARcorp.com> wrote:
> > "Aaron J. Grier" wrote:
> > > On Thu, Mar 07, 2002 at 08:10:47PM +0100, Peter Mueller wrote:
> > > > for a demo I like to "connect" a rtems application running on Linux
> > > > with a pure Linux application. How can I do that? Is there a way to
> > > > communicate between the rtems app and the pure linux app?
> > > you could use a pipe. microwindows demo uses this to communicate
> > > between a client running in RTEMS and a server running on linux.
> > > I'm sure there are more clever ways, but I have seen this method
> > > demonstrated and working. ;)
> > I've used the psim BSP to pass data via shared memory with a Linux
> > application. I added shared memory and semaphore devices to
> > psim in order to do this and they are included in the standard
> > powerpc-rtems-gdb RPMs.
> > As I recall, the UNIX port uses shared memory for the mptests so
> > it also has support for accessing shared memory. Same trick
> > is already in place there.
> Part 1.2Type: application/pgp-signature
joel at OARcorp.com On-Line Applications Research
