Problems with PSIM
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Wed Mar 13 12:32:22 UTC 2002
SMIALEK Yan wrote:
> Hello,
> I have a problem with PSIM under GDB.
> I don't know LINUX like systems very much and in spite of some answers that
> I found in the Mailing List, I don't understand who to configure PSIM.
> I managed to install all the tools and I compiled the HelloWorld
> application.
> But When I launch it, the following message appears :
> core_find_mapping() - access to unmaped address, attach a default map to
> handle this - addr=0x80000867 nr_bytes=0x1 processor=0x1020f590 cia=0x31148
> I have read some messages talking about "PSIM" configuration options and
> modifications in a script file, but I realy don't know how to proceed :-(
> Where do I have to make the modifications ? Which options ? Do I have to
> rebuild something ?
I suspect that this is a matter of trying to run gdb+psim without all
the options.  It takes a handful of options to run it since you have to
specify the memory map.  Look at the shell script in psim/tools.
psim can be linked to psim-gdb and invoked either way with the
executable as an argument.
> I work on a PC under Windows NT
> I use CYGWIN
> My target is a POWERPC "ppcn_60x"
> Thank you very much !
> Yan
