Patch/Bugfix for BOOTP in rtems-ss-20020205
Till Straumann
strauman at SLAC.Stanford.EDU
Tue Mar 19 19:35:33 UTC 2002
Thomas Doerfler wrote:
> Hi Chris,
> ok, here is a corrected verison of my patch. Thank you for
> your comments!
> wkr,
> Thomas.
OOps - I was too fast with my last posting. IMO, it is not easily
asserted that processOptions() is NOT called multiple times -
hence you could generate a memory leak. Therefore, I would
free() before strdup() [note it's to call free with a 0 arg
- your patch could also omit the NULL test]
My suggested version of the patch would read:
-- Till
diff -c bootp_subr.c.orig bootp_subr.c
*** bootp_subr.c.orig Tue Mar 19 11:24:42 2002
--- bootp_subr.c Tue Mar 19 11:34:31 2002
*** 694,700 ****
static char dhcp_gotlogserver = 0;
static struct sockaddr_in dhcp_netmask;
static struct sockaddr_in dhcp_gw;
! static char *dhcp_hostname;
static void
processOptions (unsigned char *optbuf, int optbufSize)
--- 694,700 ----
! static char *dhcp_hostname=0;
static void
*** 801,806 ****
--- 801,807 ----
if (sethostname (p, len) < 0)
panic("Can't set host name");
printf("Hostname is %s\n", p);
+ free(dhcp_hostname);
dhcp_hostname = strdup(p);
break;
*** 904,910 ****
update_files = 0;
! memset(dhcp_hostname, 0, sizeof(dhcp_hostname));
* Find a network interface.
--- 905,912 ----
update_files = 0;
! free(dhcp_hostname);
! dhcp_hostname=0;
> > > Hm, good question. At least it would not hurt. But the line I
> > > complaint is at the start of bootpc_init, long before any
> > > bootp options are processed. So at least at the first run of
> > > bootpc_init, "dhcp_hostname" is definitely NULL.
> > Any future runs if called could have dhcp_hostname set so we should free
> > the memory. It is allocated using strdup.
> > > The question is: can bootpc_init be called multiple times?
> > > Normally it will only be called once after system boot, but
> > > are there other situations?
> > A system may have some form of redundant network configuration and so
> > need to obtain a network address. This is just an example not a
> > recommendation for a network design.
> > Chris Johns, cjohns at cybertec.com.au
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_key.htm
> --- rtems-ss-20020205/c/src/libnetworking/nfs/bootp_subr.c Wed Sep 19 19:30:38 2001
> +++ /usr/local/projects/sandbox/zem40/rtems_patch/bootp_subr.c Tue Mar 19 12:39:24 2002
> @@ -902,12 +902,15 @@
> if (rtems_create_root_fs () < 0) {
> printf("Error creating the root filesystem.\nFile not created.\n");
> update_files = 0;
> - memset(dhcp_hostname, 0, sizeof(dhcp_hostname));
> + if (dhcp_hostname != NULL) {
> + dhcp_hostname = NULL;
> for (ifp = ifnet; ifp != 0; ifp = ifp->if_next)
> if ((ifp->if_flags &
