Interrupts occurrence
Angelo Fraietta angelo_f at bigpond.com
Tue Mar 26 04:09:00 UTC 2002
I have to make a correction on those previous calculations. I did not
read the settings on my CRO correctly. The actual values are 1 message
every 450 us, (not 4 us) and 1 every 500us.  So I am actually at the
extremes. The maximum transfer I could expect from a MIDI device would
be one byte every 320 us (10 bits per byte). So not setting the event
(as Chris Johns suggested) does save me a valuable 50us.
Angelo Fraietta wrote:
> After some exhaustive testing I have come up with some figures that
> represent data exchange rates between the Pic microcontroller and the
> 386 using a PLA as an interface on an ISA bus using an interrupt
> driven I/O read/write paradigm.
> What I have done is make the Pic and the 386 communicate with each
> other, each triggering an interrupt with the other, causing it to
> write to the other device.
> With the RTEMS event being triggered every  interrupt I have a
> constant exchange rate of 1 message each way every 5 us.
> Triggering the event only if the receive queue is empty gives me an
> exchange rate of 1 Message every 4 us. I am saving 1 us by not sending
> the unnecessary event.
> The big factor in this test, however, is this method that I used to
> check the exchange rates completely blows the 1 message every  650 us
> measurement I previously made away, thus proving that the interrupt
> rate will more than adequately sustain an input Midi stream running at
> maximum transfer rate (31.25kbs, which is about 3 bytes per ms)
>> You are right. Sending the event if the queue was not originally
>> empty when the ISR came is not necessary. I was already looping the
>> task until the queue was empty; I was, however, sending the event
>> regardless -- which is actually wasting CPU cycles. Thanks for the
>> tip? I'll see what I can get the interval down to by not sending an
>> unnecessary event.
>>>>Within the ISR I am doing the following:
>>>>Reading a 16 bit word from an I/O address
>>>>Decoding and adding that word onto a queue that is emptied out by a
>>>>running task
>>>>Checking a second queue for data that needs to be transmitted
>>>>Transmitting a word to the I/O card.
>>>>Setting an event that causes the running task to empty the queue.
>>>I would only send the event if the queue is empty and have the task loop
>>>until the queue is empty.
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
>>http://www.users.bigpond.com/angelo_f/
>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>There are those who seek knowledge to be known by others - that is VANITY
>>There are those who seek knowledge in order to serve - that is LOVE
>>    Bernard of Clairvaux (1090 - 1153)
>Angelo Fraietta
>PO Box 859
>Hamilton NSW 2303
>Home Page
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20020326/04a3b6b4/attachment-0001.html>
