MCF5272 Network Driver Problems
Chris Johns cjohns at cybertec.com.au
Wed May 1 22:30:58 UTC 2002
Brett Swimley wrote:
> I'm using gdb and a modified version of the BDM Driver which you and Chris
> Johns are familiar with.  I've hacked gdb to poll memory locations which my
> console driver uses to allow printfs to go to gdb, rather than out a serial
> port.  Do you suppose that the background BDM reading of processor memory
> could be interfering?
This will effect the performance and as the BDM is sort of a bus master
in this case could have other problems. I would not do this until you
have something working.
 Chris Johns, cjohns at cybertec.com.au
