Exception 6
Angelo Fraietta angelo_f at bigpond.com
Fri May 3 04:09:30 UTC 2002
I now have the problem again. The error I get from the DIMMPC (which is
an SX) is as follows:
Exception 6 caught at PC 3ff091 by thread 134283266
EAX = 7d203cf7 EBX = 0 ECX = 74 EDX = F000e2c3
ESi = 2 EDI = 0 EBP = 18D5BF ESP = CE4
Errror code (if not 0) = 0
For the 386DX, I get This error
Exception 13 caught at PC1 by thread 134283266
EAX = 0 EBX = 0 ECX = 1C EDX = F000e2c3
ESi = 0 EDI = 173EF8 EBP = 18E384 ESP = 18E324
Error code (if not 0) = F000
If I start adding and removing sections of code, the error changes. For
example, I removed code from within an interrupt handler that I had not
enabled, the error has gone.
Any suggestions on What to Do?
Joel Sherrill wrote:
>Angelo Fraietta wrote:
>>I forgot to say I am using pc386dx bsp
>>>What could be causing an exception 6. I have looked in cpu.h and it
>>>saya it is an illegal instruction.
>>>What causes this type of fault?
>I think this means invalid instruction which likely means you have
>corrupt code or jumped somewhere wrong.
>Was the reported address inside or outside your program?
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
>>http://www.users.bigpond.com/angelo_f/
>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>There are those who seek knowledge to be known by others - that is VANITY
>>There are those who seek knowledge in order to serve - that is LOVE
>>    Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20020503/08b00167/attachment.html>
