Exception 6
Angelo Fraietta
angelo_f at bigpond.com
Fri May 3 04:53:07 UTC 2002
The really frustrating part of this is that I have a build that runs
fine on the DX, but if I attempt to run it on the DIMMPC it crashes. I
have the same amount of memory on both machines, and the section of code
that causes it to crash used to run fine.
Angelo Fraietta wrote:
> I now have the problem again. The error I get from the DIMMPC (which
> is an SX) is as follows:
> Exception 6 caught at PC 3ff091 by thread 134283266
> EAX = 7d203cf7 EBX = 0 ECX = 74 EDX = F000e2c3
> ESi = 2 EDI = 0 EBP = 18D5BF ESP = CE4
> Errror code (if not 0) = 0
> For the 386DX, I get This error
> Exception 13 caught at PC1 by thread 134283266
> EAX = 0 EBX = 0 ECX = 1C EDX = F000e2c3
> ESi = 0 EDI = 173EF8 EBP = 18E384 ESP = 18E324
> Error code (if not 0) = F000
> If I start adding and removing sections of code, the error changes.
> For example, I removed code from within an interrupt handler that I
> had not enabled, the error has gone.
> Any suggestions on What to Do?
>>>I forgot to say I am using pc386dx bsp
>>>>What could be causing an exception 6. I have looked in cpu.h and it
>>>>saya it is an illegal instruction.
>>>>What causes this type of fault?
>>I think this means invalid instruction which likely means you have
>>corrupt code or jumped somewhere wrong.
>>Was the reported address inside or outside your program?
>>>Angelo Fraietta
>>>PO Box 859
>>>Hamilton NSW 2303
>>>Home Page
>>>http://www.users.bigpond.com/angelo_f/
>>>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>>>There are those who seek knowledge to be known by others - that is VANITY
>>>There are those who seek knowledge in order to serve - that is LOVE
>>> Bernard of Clairvaux (1090 - 1153)
>Angelo Fraietta
>PO Box 859
>Hamilton NSW 2303
>Home Page
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20020503/22f6d6ca/attachment.html>
