MP3 player, IDE interface
Eugeny S. Mints jack at oktet.ru
Wed May 8 05:05:38 UTC 2002
Peter,
On Tue, 7 May 2002, Peter Mueller wrote:
> Hi RTEMS users,
> I want to build a MP3 player based on a 332 board / VS1001 MP3 Decoder and
> an IDE Disk to store music files. VS1001 seems to be no problem. Hard
> disk access and especially the files system seems to be much harder to
> achieve.
Two filesystems are currently available in RTEMS - IMFS and DOSFS. IMFS -
is in-memory filesystem and hence is not appropriate for you. DOSFS is
MSDOS-like(and compatible:) filesystem and available since rtems snapshot
at 01 of March.
Also currently noboby has announced any driver for IDE disks for RTEMS,
but floppy driver was announced.
> Has anybody already built a hard disk driver for rtems?
As I know - nobody.
>I need no DMA.
> PIO mode is ok.
> Any other hints?
> Thanks,
> Peter
> "This is an object-oriented system.
> If we change anything, the users object."
Eugeny S. Mints
OKTET Ltd.
1 Ulianovskaya st., Petergof, St.Petersburg, 198904 Russia
Phone: +7(812)428-4384 Fax: +7(812)327-2246
mailto:Eugeny.Mints at oktet.ru
