Novice problems with psim powerpc
Jack Cawkwell J.Cawkwell at open.ac.uk
Wed May 8 09:39:14 UTC 2002
Hello,
I am still having problems starting powerpc-rtems-gdb
and hello.nxe on Linux i686, using psim.
The output is typically
psim
./rtems-obj-20020301/powerpc-rtems/c/dmv177/tests/samples/hello/o-optimize/hello.nxe
core_find_mapping() - access to unmaped address, attach a default map to
handle this - addr=0xf20000af nr_bytes=0x1 processor=0x40156008 cia=0x427b4
psim
./rtems-obj-20020301/powerpc-rtems/c/dmv177/tests/samples/hello/o-optimize/hello.exe
/openprom/init/stack: Unfinished procedure create_ppc_aix_stack_frame
psim
./rtems-obj-20020301/powerpc-rtems/c/eth_comm/tests/samples/hello/o-optimize/hello.exe
handle this - addr=0x800000 nr_bytes=0x4 processor=0x40156008 cia=0x10038
Any help would be very much appreciated. Could this be
a problem with the versions.
Jack
