TAO version for rtems
Tue May 14 13:16:53 UTC 2002
Jack Cawkwell wrote:
> Hello,
> I have tried to build ACE/TAO for rtems, using the
> latest ACE/TAO tarball, but it failed almost immediatley.
> Are the TAO fixes for rtems in the latest ACE/TAO 5.2/1.2
> or does this need a beta, or to use the cvs repository?
I built with pre-releases so anything you are noting now
would be setup issues or regressions.  What is failing?
You have to have a BSP installed and RTEMS_MAKEFILE_PATH
set to point to that BSP.  Otherwise, it won't be able to
find the right settings for CC, CFLAGS, etc.  The ACE/TAO
RTEMS configuration files depend on the RTEMS application
Makefiles to obtain information.
> Thanks, Jack
