How to build tests?
Scott Newell newell at cei.net
Wed May 15 05:00:53 UTC 2002
I know this is a silly question, but how do you configure and build the
test suite in 4.5.0?  I'm targeting a modified m68k/efi332 BSP, and I've
tried adding --enable-tests to my configure command, and then doing the
'make test', but there's not a target for test.
The samples are being built, but I cannot locate the timing tests (for
instance), or even a makefile for the timing tests.
thanks,
newell
