How to build tests?
Ian Caddy ianc at microsol.iinet.net.au
Wed May 15 05:25:55 UTC 2002
Hi Scott,
Have you tried to use: make all
This should build RTEMS and the samples and the test suite if you have
--enable-tests in your configure.
Talk to you soon,
Ian Caddy
Scott Newell wrote:
>I know this is a silly question, but how do you configure and build the
>test suite in 4.5.0?  I'm targeting a modified m68k/efi332 BSP, and I've
>tried adding --enable-tests to my configure command, and then doing the
>'make test', but there's not a target for test.
>The samples are being built, but I cannot locate the timing tests (for
>instance), or even a makefile for the timing tests.
>thanks,
>newell
Microsol (Aust) Pty Ltd
Phone: (+61) 08 9473 6600
Fax:   (+61) 08 9473 6699
