pc386 BSP - is it still supported?
Angelo Fraietta
angelo_f at bigpond.com
Sun May 19 22:27:19 UTC 2002
I just ran the unlimited test on my machine (direct from the samples
with no modification from me) and they worked. Did you modify the code
at all or did you run the sample direct from samples directory?
Robin Iddon wrote:
> Hi,
> I have tried to use the pc386 BSP with limited success.
> I started off with the 4.5.0 release, and I could build the BSP and
> boot it with GRUB onto my target.
> However, the "unlimited.exe" test appears to fail with hundreds of
> "thread exceptions" being reported to the console. I tried to add in
> some "getc(stdin)" to the code to allow me to work out which of the
> three tests was causing the failure, but they caused it to hang
> (presumably stdin isn't the PC keyboard).
> The hello test does work, so it is something a little more subtle than
> it just not working.
> Anyway, I noticed that the whole 4.5.0 release is no quite old, so I
> downloaded the latest snapshot. Unfortunately that doesn't build for
> the pc386 BSP.
> I am using the recommended compiler chain running under Linux.
> Can anyone offer me some advice on what to look for?
> Thanks in advance,
> Robin Iddon
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20020520/cdfa8c32/attachment.html>
