network support
Sachin K sachin at dexceldesigns.com
Mon May 20 07:42:57 UTC 2002
hi,
i have installed rtems-4.5.0 on my redhat Linux 7.2.
as stated in README.configure, posix and network support
will be enabled by default,
I tried to install rtems just by entering "../rtems-4.5.0/configure" from my
"./build" directory,  everything went perfect but, the file
"/usr/local/posix/make/bsp.cfg" contains following information
## BSP configuration flags for BSP "posix"
## Does this BSP support multiprocessing ?
HAS_MP = no
## Does this BSP support RTEMS's remote debugger ?
HAS_RDBG = no
## Does this BSP support RTEMS's posix API ?
HAS_POSIX_API = no
## Does this BSP support RTEMS's ITRON API ?
HAS_ITRON_API = no
## Does this BSP support RTEMS's CXX API ?
HAS_CPLUSPLUS = no
## Does this BSP support RTEMS's networking ?
HAS_NETWORKING = no
## Only used for the bare bsp
BARE_CPU_MODEL =
BARE_CPU_CFLAGS =
it says that posix and n/w is not supported,
can anyone plz tell me how to enable this??
TIA
Sachin K
Dexcel Electronics Designs (P) Ltd., Bangalore, India
