ISR to task scheduling help
Aaron J. Grier
aaron at frye.com
Wed May 22 18:29:46 UTC 2002
I'm in the process of trying to convert what used to be an ISR into a
task, but having a heck of a time.
the task is a hardware handler -- it needs to wake up, check to see if
there's any work to do and do it, and if not, go back to sleep.
my initial thought was to make it a high priority task with
(RTEMS_NO_TIMESLICE | RTEMS_NO_PREEMPT), and then use
rtems_rate_monotonic_period(period_id, 1); to get it to run on every
tick, but the delay between clock tick and return from
rtems_rate_monotonic_period varies more than I would like.
here's a distribution of timing from the clock tick handler, which
subsequently calls rtems_clock_tick(). each of the bins is 1/256th of a
clock tick. (it's my sampling clock.):
{0 <repeats 147 times>, 1, 0 <repeats 69 times>, 2, 2142,
0 <repeats 37 times>}
here's the distribution I see in the task:
{0 <repeats 60 times>, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1,
0 <repeats 151 times>, 96, 0, 2026, 0 <repeats 21 times>, 15, 2, 1, 0,
0, 0, 0, 0, 0}
aside from a tick of startup noise, the clock tick is tightly clustered
around bin 218, and I would expect to see similar distribution in my
task, but it's smeared.
am I misunderstanding how the rate monotonic manager works? is there a
way to get more consistent timing?
I'm going to try using RTEMS timers next. it looks like they get run
before any of the task scheduling, and I might be able to eliminate the
"work to do" check (since the timer will never be fired if there isn't
any work to do) and I'm hoping I can get more consistent timing. just
figured I'd check in here to make sure I'm still sane and on the right
track.
thanks.
Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
