instalations problems
Jim Robinson jrobinson at sierra-idt.com
Fri May 31 12:41:08 UTC 2002
I get the same problem with the gcc for Powerpc, but mine is with libm.
I also found that the latest snapshot of Rtems fails to build the mvme162
bsp.
just my 2 cents. ;-)
Jim
Francisco SANCHEZ wrote:
> I am trying to install the RPM from the RPM 4.5.0
> i386-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.rpm
> and I am getting this error,
> error: unpacking of archive failed on file
> /opt/rtems/bin/sh-rtems-gcc;3cf7642f: cpio: MD5 sum mismatch
> I have tryed to install it from the CD and also I have downloaded that
> specific RPM from rtems web page. I get thes same error in both cases.
> Is there any solution or I must compile rtems.
> thanks in advance
