A problem about sparc-rtems-gcc
Justin Cui justin_cui at 21cn.com
Tue May 28 16:51:01 UTC 2002
hi,
	I downloaded the lastest cygwin and installed.Then I downloaded the source of rtems4.5.0.
I unzipped the source as the instructions in the documents of rtems4.5.0. Just untar it to
a directory and patched it and no rej files were generated. I configured the binutil and make
all info install. then I configured the gcc. when I "make all" in the b-gcc, the makeinfo.exe
didn't work! I changed it with the makeinfo.exe of cygwin and managed to complete the make.
And then I build the gdb with no problems. When I was going to build the rtems4.5.0 sources,
I found that the sparc-rtems-gcc doesn't work! the error message are as follows:
$ sparc-rtems-gcc -v -c f.c
Reading specs from /opt/rtems/lib/gcc-lib/sparc-rtems/2.95.2/specs
gcc version 2.95.2 19991024 (release)
 /opt/rtems/lib/gcc-lib/sparc-rtems/2.95.2/cpp.exe -lang-c -v -D__GNUC__=2 -D__G
NUC_MINOR__=95 -Dsparc -D__GCC_NEW_VARARGS__ -Drtems -D__rtems__ -D__sparc__ -D_
_GCC_NEW_VARARGS__ -D__rtems__ -D__rtems__ -D__sparc -D__rtems -Asystem(rtems) -
Acpu(sparc) -Amachine(sparc) f.c /cygdrive/d/DOCUME~1/chc.B3/LOCALS~1/Temp/ccyiW
lGl.i
GNU CPP version 2.95.2 19991024 (release) (sparc)
#include "..." search starts here:
#include <...> search starts here:
 /opt/rtems/lib/gcc-lib/sparc-rtems/2.95.2/include
 /opt/rtems/lib/gcc-lib/sparc-rtems/2.95.2/../../../../sparc-rtems/include
End of search list.
The following default directories have been omitted from the search path:
 /opt/rtems/lib/gcc-lib/sparc-rtems/2.95.2/../../../../include/g++-3
 /opt/rtems/lib/gcc-lib/sparc-rtems/2.95.2/../../../../sparc-rtems/sys-include
End of omitted list.
 /opt/rtems/lib/gcc-lib/sparc-rtems/2.95.2/cc1.exe /cygdrive/d/DOCUME~1/chc.B3/L
OCALS~1/Temp/ccyiWlGl.i -quiet -dumpbase f.c -version -o /cygdrive/d/DOCUME~1/ch
c.B3/LOCALS~1/Temp/ccILYU3E.s
GNU C version 2.95.2 19991024 (release) (sparc-rtems) compiled by GNU C version
2.95.3-4 (cygwin special).
 /opt/rtems/sparc-rtems/bin/as.exe
Assembler messages:
 for reading.open
: No such file or directory
-- end of error messages
Sincerely,
Justin
