termios and non-blocking write()
Daniel Néri dne at mayonnaise.net
Fri May 10 23:50:59 UTC 2002
Joel Sherrill <joel.sherrill at OARcorp.com> writes:
> Daniel Néri wrote:
>> I ended up hacking the kernel to use a spare c_cc[] entry as a
>> flag, which if non-zero, provides microsecond VTIME granularity.
Oops, I meant "millisecond" here...
> The limitation is ultimately the clock tick quantum which is the
> basis for all timing.
Right. The BSD kernel uses microseconds internally so this was no
problem (on modern hardware).
Regards,
   --Daniel
Daniel Neri
