remote debugger for dmv-177
Shanmugavel Ponnusamy sponnu1 at umbc.edu
Tue May 28 11:49:50 UTC 2002
Thank you very much for your help.
with regards,
Joel Sherrill wrote:
> Shanmugavel Ponnusamy wrote:
> > hi,
> >   can you please inform me whether remote debugger is available for
> > dmv-177 for rtems-4.5.0 or higher versions? i am currently using printf
> > statements. is there any other way to debug rtems applications?
> We debugged the BSP using a JTAG emulator.  The ROM monitor is
> pretty sad and I don't recall a serial remote stub for gdb
> and powerpc at the time.
> The best thing to do would be to update the dmv177 BSP to use the
> new exception processing model and use the remote ethernet debugger.
> > thanks in advance,
> > Shanmugavel ponnusamy
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
