RTEMS Development using Redhat 7.2 or 7.3???
gregory.menke at gsfc.nasa.gov
Wed May 29 14:33:40 UTC 2002
> We have been using Redhat 6.2 and have run into several instances
> where the old distribution has made it near impossible to install some
> of the newer releases of tools (DDD). We are considering upgrading to
> Redhat 7.2 or 7.3. Is anyone on the list using either of these
> distributions and it so, what success have you enjoyed?
> Thanks in advance.
Yeah, rpms can make this a little troublesome. I've often used rpm by
hand with --nodeps and/or --force to make RedHat Just Do It. You
might try compiling ddd from source as its pretty straightforward and
shouldn't present too much trouble on 6.2
Gregm
