unlimited (was Re: task notepad question)
Chris Johns cjohns at cybertec.com.au
Wed Nov 6 01:07:17 UTC 2002
Joel Sherrill wrote:
> NOTE: The set of POSIX keys is not enlarged if you use unlimited tasks.
Does the user get the correct error code in the current code ?
Do any other parts of the POSIX API suffer from this problem or is it
just threads (tasks!) ?
This is also the case with User Extensions and the drivers table. You
can add drivers after starting, but the number is fixed. Any others ?
I can raise a PR for this and list all the areas that need to be looked at.
I have not looked at the POSIX implementation so far :-). Are keys
handled in one spot ?
  Chris Johns, cjohns at cybertec.com.au
