bootstrap
gregory.menke at gsfc.nasa.gov
Wed Nov 6 03:14:33 UTC 2002
Hi,
I'm trying to work up a bsp for the Motorola MTX-60x boards, based on
the motorola_powerpc bsp- that part is under control but I'm having
trouble doing the bootstrap that sets up the new
directories/makefiles/configure scripts. After bootstrapping, when I
configure, I get this error right away;
configure: creating ./config.status
configure: configuring in ./tools/update
configure: running /bin/sh
'../../../../opt/rtems/rtems-ss/tools/update/configure' --prefix=/opt/rtems/build/mcp750
--host=i686-pc-linux-gnu --build=i686-pc-linux-gnu --target=powerpc-rtems '--prefix=/opt/rtems/build/mcp750'
'--disable-itron' '--enable-network' '--enable-rtemsbsp=mcp750' ' '--enable-cxx' --cache-file=/dev/null
--srcdir=../../../../opt/rtems/rtems-ss/tools/update
../../opt/rtems/rtems-ss/configure: eval: line 1: unexpected EOF while looking for matching `''
../../opt/rtems/rtems-ss/configure: eval: line 2: syntax error: unexpected end of file
configure: error: /bin/sh '../../../../opt/rtems/rtems-ss/tools/update/configure' failed for tools/update
Indents added by me. There seems to be a mismatched quote between the
enable-rtemsbsp and the enable-cxx. It looks like configure isn't
handling the quotes right when it passes the cmdline to the subsequent
invocations. When building a bsp normally from an unmodified
snapshot, configure & make complete OK. I'm using;
automake 1.7.1
autoconf 2.54
m4 1.4
The error has been identical on 2 different machines and I've tried a
few different versions of automake/autoconf as well- no changes in the
error. bootstrap runs to completion with a couple warnings related to
the 386 bsp's. README.configure looks more or less hopelessly out of
date, and seems to have a typo related to the automake version
requirement, as there is no automake ver 1.14 that I've seen.
Thanks for any help,
Gregm
