RTEMS on MCP750 and MTX-60x, for Eric Valette
Chris Caudle
chris at chriscaudle.org
Thu Nov 7 18:02:59 UTC 2002
On Thursday 07 November 2002 12:52 pm, gregory.menke at gsfc.nasa.gov wrote:
> - In registers.h, you lay out the HID0 bits as leftwards bit shifts,
> but the Motorola docs lay out the bits with LSB leftmost,
If the Motorola docs are like the IBM docs, the leftmost is actually MSB,
but it it called bit 0. LSB is then bit 31 (e.g. in a 32 bit register).
Chris Caudle
