Problem building C++ Program
Dieter Schaefer
Dieter.B.Schaefer at t-online.de
Mon Nov 11 13:56:43 UTC 2002
Hello all,
I'm in the middle of porting RTEMS SS-20021007 to a PowerPC based board. So far,
things went quite successful. The included samples like hello.exe, ticker.exe,
cdtest.exe etc. work as expected.
Now I have problems to get my own C++ programs build. I've started with Makefile.leaf
found in /opt/rtems/make/Template. It works ok for plain C programs, however it fails
to build C++ programs. (Looks like it doesn't link the proper libraries)
Any suggestions what to add or modify?
Another question related to this template Makefile.leaf is how to generate a linker
map? The parameter "-Map Target.map" is either not passed to the linker, or not
recognized by gcc. All I could go to work was the "-M" option ... sending the linker map
to stdout.
Any help and suggestions are appreciated.
Thanks,
Dieter
