Linux distribution
Wed Nov 13 14:18:19 UTC 2002
Sudheesh J wrote:
> If I understood your problem, I have successfully compiled a BSP(pc386) on
> my Redhat 7.3 box from rtems ss-20021007.
The main OAR RTEMS machine is running RedHat 7.3 but I know that other
maintainers use different distributions.  Ralf Corsepius is a SuSE user
and Eric Norum uses MacOS X.
> ----- Original Message -----
> From: <silverio.di at qem.it>
> To: <rtems-users at oarcorp.com>
> Sent: Wednesday, November 13, 2002 5:57 AM
> Subject: Linux distribution
> > In the past I've used RTEMS 4.5.0 with cygwin tool.
> > New snapshot release cooming without cygwin support tools so I must use
> > Linux how Host.
> > I can have the RedHat 7.3 Linux version already installed in headquarters
> > of my factory.
> > Before to require and install that, is it a valid host environment for
> > rtems tool-chain ?
> > What is the best (another version, another type eg:SUSE, MANDRAKE) ?
> > Thank you
> > Silverio
