Query based on :  LILO for RTEMS
    Erwin Rol
    erwin at muffin.org
    Thu Nov 14 20:25:37 UTC 2002
Hello Rakesh,
As you can see in the email header i also sent this mail to the RTEMS
list, which is normaly the best place to ask "gerneral" questions. I
personaly don't know grub to well , and can't really give you any help
on that topic, i just sugested trying it to make sure the problem you
had was really lilo related.
To everybody else, just read the mails below and maybe someone can give
Rakesh some help ?
- Erwin
On Thu, 2002-11-14 at 07:50, Rakesh.V.R wrote:
> Hi Erwin,
>      Thanks for your reply. I tried to boot with GRUB following the
> directions specified in the HOWTO doc, provided along with the RTEMS
> snapshot. But on giving the "install" command, "File Not Found" error is
> displayed. I've attached the HOWTO doc with this mail.
> I tried using plex86 simulator. Still not successful to run RTEMS based
> application. Expecting your suggestions.
> Thanks,
> Rakesh
> ----- Original Message -----
> From: "Erwin Rol" <erwin at muffin.org>
> To: "Rakesh.V.R" <rakesh at atinav.com>
> Sent: Thursday, November 14, 2002 2:44 AM
> Subject: Re: Query based on : LILO for RTEMS
> > Hello Rakesh,
> > On Thu, 2002-11-07 at 07:17, Rakesh.V.R wrote:
> > > Hello Erwin,
> > >     I configured and build RTEMS for target i386-rtems and pc386 bsp.
> > Then I
> > > edited the path in Makefile.inc provided in your liloboot package to
> > the
> > > sample helloworld application created. I created the zImage and tried
> > to
> > > boot the same using lilo. System successfully booted to RTEMS. But
> > instead
> > > of printing *** HELLO WORLD TEST ***, etc specified in the printf()
> > > statements, it printed number 8000 for some 10 times and stopped.
> > Could you
> > > please suggest something in this regard.
> > Hmmm hard to say, i wrote the lilo stuff a _long_ time ago so it might
> > be something with the newer RTEMS kernels that goes wrong. Did you try
> > to boot with grub to verify that RTEMS itself works on your hardware ?
> > > Is there any good pc386 emulator, which can be used for running the
> > > application?
> > I used BOCH's to boot RTEMS, that should still work. Else you can try
> > vmware. BOCH's is opensource vmware is closed commercial software.
> > I know the reaction was a bit slow, but i hope it still helps you a bit,
> > Erwin
> > > Thanks,
> > > Rakesh
> > > To: "RTEMS" <rtems-users at oarcorp.com>
> > > Sent: Saturday, January 29, 2000 3:57 AM
> > > Subject: LILO for RTEMS
> > > > Hello all,
> > > > due to the positive reactions here the source to
> > > > make a image that can be booted with lilo.
> > > > Few notes:
> > > > it is hacked linux kernel code, which makes it GPL.
> > > > The Makefile.inc holds the path to the "image" that should
> > > > be booted. after a 'make' you will have a zImage wich can
> > > > be dd'ed to floppy or booted with lilo.
> > > > lilo offers the possibility pass boot parameters and to pass
> > > > the memory size and it sets up the video modes.
> > > > These things might be usefull for the pc386 BSP ?
> > > > also I am interested to see if it solves those strange reboot
> > problems.
> > > > I never have had serious problems with the 4.0.0 version and grub
> > and
> > > > was very supriced to see the C++/sp/hello wolrd (the only ones i
> > tried)
> > > > worked in one go now.
> > > > I hope it is usefull and maybe can be integrated in the pc386 BSP
> > (even
> > > > though
> > > > it is GPL)
> > > > - Erwin
> > > > PS. can someone tell me what the best way would be to interegrate
> > this
> > > > into the
> > > > build process ? now i run make manualy on it and have to chnage the
> > > > image name in the makefile.
Type: application/pgp-signature
Desc: This is a digitally signed message part
URL: <http://lists.rtems.org/pipermail/users/attachments/20021114/fee7762e/attachment.bin>
