new snapshot (ss-20021118), etc
Mon Nov 18 21:46:10 UTC 2002
Stephen Holford wrote:
> Hi
> As with the 20021111 snapshot, I get the following non-fatal configure
> errors with the 20021118 snapshot. I'm running redhat 7.1 with the
> latest autoconf (2.52) and automake (1.62) from the OAR site. The build
> process completes in spite of the errors. The 20021007 snapshot does not
> exhibit this behaviour.
Thanks for reporting this last time.  Ralf is looking into it.  He is
trying
to resolve conflicts between various versions of automake/autoconf and
this
is unfortunately a side-effect.  This will be fixed before we branch.
> I used the following command line:
>   $ /home/rtems/tools/rtems-ss-20021118/configure --prefix=/opt/rtems
> --target=powerpc-rtems --disable-networking --disable-posix
> --disable-docs --disable-itron --disable-tests
> --enable-bare-cpu-cflags=-mcpu=603e -mstrict-align -Dmpc8260
> -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF
> --enable-bare-cpu-model=mpc8260 --enable-maintainer-mode
> --enable-rtemsbsp=bare
> Some of the captured output:
> checking for gmake... gmake
> checking for RTEMS Version... ss-20021118
> checking build system type... i686-pc-linux-gnu
> checking host system type... i686-pc-linux-gnu
> checking target system type... powerpc-unknown-rtems
> checking for a BSD compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for mawk... mawk
> checking whether gmake sets ${MAKE}... yes
> checking whether to enable maintainer-specific portions of Makefiles... yes
> checking if the test suites are enabled? ... no
> /home/rtems/tools/rtems-ss-20021118/configure: eval: line 1: unexpected
> EOF while looking for matching `''
> /home/rtems/tools/rtems-ss-20021118/configure: eval: line 2: syntax
> error: unexpected end of file
> configure: creating ./config.status
> configure: configuring in ./tools/update
> Steve Holford
