new snapshot (ss-20021118), etc
Stephen Holford SHolford at WESCAM.com
Mon Nov 18 22:48:59 UTC 2002
Hi Ralph
Actually the "command line" in that post is ripped from the config.log
file thats automagically generated by the build process. My actual
command line is generated by a shell script along the lines of:
BARE_FLAGS="-mcpu=603e -mstrict-align -Dmpc8260 -DPPC_ABI=PPC_ABI_EABI
-DPPC_ASM=PPC_ASM_ELF"
${RTEMS_TOP}/configure \
--prefix=${PREFIX} \
--target=${TARGET} \
--disable-networking \
--disable-posix \
--disable-docs \
--disable-itron \
--disable-tests \
--enable-bare-cpu-cflags="${BARE_FLAGS}" \
--enable-bare-cpu-model=${CPU_MODEL} \
--enable-maintainer-mode \
--enable-rtemsbsp=bare 2>&1 | tee config.out
This has worked with every RTEMS snapshot until the 20021111 one.
Here's an early configure line in the make process,
configure: configuring in ../../cpukit
configure: running /bin/sh
'/home/rtems/tools/rtems-ss-20021118/c/src/../../cpukit/configure'
--prefix=/opt/rtems --host=powerpc-rtems --build=i686-pc-linux-gnu
--target=powerpc-rtems --disable-networking --disable-posix
--disable-docs --disable-itron --disable-tests
'--enable-bare-cpu-cflags=-mcpu=603e -mstrict-align -Dmpc8260
-DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF'
--enable-bare-cpu-model=mpc8260 --enable-maintainer-mode
--with-target-subdir=powerpc-rtems
--exec-prefix=/opt/rtems/powerpc-rtems build_alias=i686-pc-linux-gnu
host_alias=powerpc-rtems target_alias=powerpc-rtems RTEMS_BSP=bare
build_alias=i686-pc-linux-gnu host_alias=powerpc-rtems
target_alias=powerpc-rtems '--with-project-root=../../'
'--enable-rtemsbsp=bare'
    --cache-file=/dev/null
--srcdir=/home/rtems/tools/rtems-ss-20021118/c/src/../
It looks like a ' and ' end up around the --enable-bare-cpu-cflags.
Here's a build line
powerpc-rtems-gcc --pipe -isystem ../../../../../bare/lib/include
-DHAVE_CONFIG_H    -D__RTEMS_INSIDE__ -ansi -fasm      -O1
-fomit-frame-pointer -g -O2 -mcpu=603e -mstrict-align -Dmpc8260
-DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF  -o o-optimize/apiext.o -c
/home/rtems/tools/rtems-ss-20021118/c/src/../../cpukit/score/src/apiext.c
Again the cflags look like they all got inserted correctly.
Steve
