new snapshot (ss-20021118), etc
Ralf Corsepius corsepiu at faw.uni-ulm.de
Mon Nov 18 23:38:20 UTC 2002
Am Mon, 2002-11-18 um 23.48 schrieb Joel Sherrill:
> Ralf Corsepius wrote:
> > Am Mon, 2002-11-18 um 22.46 schrieb Joel Sherrill:
> > > Stephen Holford wrote:
> > > > Hi
> > > > As with the 20021111 snapshot, I get the following non-fatal configure
> > > > errors with the 20021118 snapshot. I'm running redhat 7.1 with the
> > > > latest autoconf (2.52) and automake (1.62) from the OAR site. The build
> > > > process completes in spite of the errors. The 20021007 snapshot does not
> > > > exhibit this behaviour.
> > > Thanks for reporting this last time.  Ralf is looking into it.  He is
> > > trying
> > > to resolve conflicts between various versions of automake/autoconf and
> > > this
> > > is unfortunately a side-effect.
> > True. However this problem only occurs if using whitespace separated
> > lists as arguments to configure options,
> > eg.
> > configure .. --enable-rtemsbsp="foo bar"
> > or
> > configure .. --enable-bare-cpu-cflags="-Dfoo -Dbar"
> > If not using whitespaces, everything should work out fine.
> I am confused. Is this a configure invocation problem or the same
> as PR312?
Both.
Stephen quotes improperly, which then triggers the bug. If he had quoted
properly, a he would have encountered similar problems later.
[Background: autoconf's internal quoting of configure arguments has
changed. These quoted configure arguments are processed and passed down
to subdirectory configure scripts. During this processing quoting of
lists gets lost and causes them to be passed as separate arguments
instead of one.]
Ralf
