Fwd: --enable-maintainer-mode don't seem to work
Poletti Francesco fpoletti at libero.it
Tue Nov 19 14:29:20 UTC 2002
----------  Messaggio inoltrato  ----------
Subject: --enable-maintainer-mode don't seem to work
Date: Tue, 19 Nov 2002 15:24:33 +0100
To: Ralf Corsepius <corsepiu at faw.uni-ulm.de>
I try whit the --enable-maintainer-mode but nothing, may be a problem of my
bsp? I'm using the rtems-ss-20021111 snapshot and my configure opotions are
--target=arm-rtems --enable-maintainer-mode --enable-rtemsbsp=arm_bare_bsp
--enable-debug --enable-tests --prefix=/home/tesi16/rtems
Into arm_bare_bsp I put my code.
Thank to all Francesco
> Am Die, 2002-11-19 um 12.27 schrieb Poletti Francesco:
> > I don't understand this probelm, tell me If I mistake: I'm developing a
> > board, when I make one changes into a file (like irq.c in the irq
> > directory of my board) and I returned into the build directory If I put
> > the make all install command the modific isn't put in the new build.
> configure .. --enable-maintainer-mode ..
> Ralf
