I have build rtems with --enable-mainteiner-mode I don't know if is normal but when I make changes to bsp and after I put the make all install command in the build directory the gcc rebuild the bsp. But when the build enter in the samples directory it do rebuilt it... For me isn't a big problem, but is normal? Tanks to all Francesco
