Anyone using ACE with RTEMS?
Jack Cawkwell J.Cawkwell at open.ac.uk
Thu Nov 21 08:12:28 UTC 2002
Phil,
I am hoping to use ACE/TAO under RTEMS, and tried to test it about
6 months ago. I am new to RTEMS and had trouble building for a number
of reasons, and stopped so that I could continue to develop my application
under Linux. Most of my app should work under Linux, so I am under no
pressure. I could probably help with testing as I am in a better position
to do the RTEMS build now. This is in support of a part-time PhD so time
is in short supply ;=)
I will also need to port the OpenCV library to RTEMS at some time. Has this
been done by anyone, or does anyone know how difficult it might be?
Jack
ptorre at zetron.com writes:
>I'm trying to get the most recent stable ACE library to work with
>rtems-ss-20020628, and wondered if anyone else has played with this.
>RTEMS is one of the targets that ACE knows about, but I'm having a
>few problems getting it going.  The current problem is that the
>first thing ACE does is create a POSIX condition variable, and then
>does a pthread_cond_wait() on it with no other threads running.  It
>looks like RTEMS is doing everything it should, so I'm asking about
>this on the ACE list also; just wondered if any RTEMS users had been
>here before me.  :)
>Thanks,
>-Phil
>Phil Torre                               phone: 425-820-6363 x234
>Design Engineer                          email: ptorre at zetron.com
>Switching Systems Group                    fax: 425-820-7031
>Zetron, Inc.                               web: http://www.zetron.com
