Re: arm-rtems-gcc...no
Francesco Poletti fpoletti at libero.it
Thu Nov 21 09:58:57 UTC 2002
Hy,
I'm working with arm-rtems and for my experience I suggest you to
install the rpm for arm-rtems-gcc newlib and binutils.
In particolar you can look at the file:
ftp://ftp.oarcorp.com/pub/rtems/snapshots/rtems/ss-20021118/TOOL_VERSIONSYou
Here there are all the tools that you may need, obviosly if you cross
compile for arm-rtems you only need the rpm referred to arm and the base
ones.
You can find those file into the snapshot ftp under the tools sections.
They work very veel the only problems are that you must have the root
diricts for build rpm.
In the Getting started with RTEMS for c/c++ users you can find all the
documentation you may need!
Francesco
