m68k gcc 3.2, RTEMS 4.5.0, and crtstuff
Aaron J. Grier
aaron at frye.com
Fri Nov 22 01:13:18 UTC 2002
gcc/config/m68k/t-crtstuff used to include the line:
EXTRA_PARTS=crtbegin.o crtend.o crti.o crtn.o
somewhere after 1.1 this line was dropped, and the generic t-m68kelf
has only:
which means there's no more crti.o and crtn.o... this caused me some
grief since my linker script has a snippet like this:
/* to avoid hardcoding in link and unlink opcodes in
* here, we steal epilogues and prologues from the
* compiler... this also lets us sneak in our own
* routines if we want. */
PROVIDE (_init = .);
*crti.o(.init)
*(.init)
*crtn.o(.init)
PROVIDE (_fini = .);
*crti.o(.fini)
*(.fini)
*crtn.o(.fini)
the RTEMS script I started with had the function prologues and epilogues
(link and unlk / rts, respectively) hard-coded into this section, which
seemed a little hacky to me, but would explain why other m68k-rtems
haven't run into this... :)
I'm not sure what the situation is on the other rtems ports; if the
re-addition of crt{i,n} should be added to the global config/t-rtems
level, or somehow just for m68k.
any advice, Joel? is this of enough concern that I should file an RTEMS
PR?
Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
