OpenCVS was Re: Anyone using ACE with RTEMS?
Fri Nov 22 14:12:12 UTC 2002
Ralf Corsepius wrote:
> Am Fre, 2002-11-22 um 08.50 schrieb Jack Cawkwell:
> > Joel,
> > OpenCV is an image processing package from Intel, written in old fashioned
> > C and its open source.
> Last time, I looked into OpenCV (opencv_007) [1], it came with a couple
> of closed source, binary-only libs. I haven't looked into newer
> versions, yet.
According to the sourceforge project site for opencvlibrary, it is
now a BSD license and the copying file at the top of that distribution
looks to be a vanilla BSD style license.  But it does have a not in
the FAQ that you have to have Intel's Image Processing Library so
that must be what you remember.  But even that's contradicted by
this on Intel's OpenCV site:
Q2: I want a Linux version of the Intel® Image Processing Library, where
do I get this?
A2: OpenCV no longer depends on the Image Processing Library.
The end result is that I don't have a clue what the current
version depends on.  Jack.. could you enlighten me?
> Ralf
> [1] I considered using it for work outside of and not related to RTEMS,
> but didn't use it in the end.
