How to download RTEMS to the target board ?
Wed Nov 27 14:10:01 UTC 2002
> Howard wrote:
> Hi all.
>     How to download RTEMS to the target board ? ( cpu:arm ;
> bsp:arm_bare_bsp )
This is all board dependent.  You might have a ROM monitor which
downloads across the net or download using a debugger or
processor emulator.  So it depends upon your board.
Worse, I think the arm_bare_bsp is an early example of an
ARM BSP because the initial port was to a proprietary ARM
variant.  I do not think it corresponds to any real hardware
and is certainly not intended to be functional without work.
I posted a couple of weeks ago about obsoleting it and removing
it since it didn't serve a role anymore.
>     Thanks a lot !
>     Howard.
