task notepad question
Wed Nov 6 00:49:53 UTC 2002
Chris Johns wrote:
> Till Straumann wrote:
> > Does someone know if the notepad locations have a defined
> > value after creation of a task?
> The only place I can find in the code that sets "Notepads" is in
> tasksetnote.c so I would have to assume they are not initialised.
> $ grep Notepads `find cpukit \( -name \*.[hc] -o -name \*.inl \)`
Trust the source. :)
POSIX keys are set to zero if that helps.
NOTE: The set of POSIX keys is not enlarged if you use unlimited tasks.
>   Chris Johns, cjohns at cybertec.com.au
