unlimited (was Re: task notepad question)
Chris Johns
cjohns at cybertec.com.au
Wed Nov 6 02:06:24 UTC 2002
Joel Sherrill wrote:
> >>NOTE: The set of POSIX keys is not enlarged if you use unlimited tasks.
> >Does the user get the correct error code in the current code ?
> What would it be and who would trigger it? All tasks/threads are
> supposed to have a key slot.
Does a POSIX app that creates more threads than keys with the task
number set to unlmited handle the error correctly ?
> >Do any other parts of the POSIX API suffer from this problem or is it
> >just threads (tasks!) ?
> I think that it is just keys. I think you can extend the number of
> POSIX threads. But keys are different.
I think I need to look at the way this is implement to see the relationship.
> >This is also the case with User Extensions and the drivers table. You
> >can add drivers after starting, but the number is fixed. Any others ?
> I don't think this is that bad a problem. It is just a configuration
> limit.
I suspect this depends on where you view the configuration table
resides. I have the configuration in the BSP not the application and the
BSP is built separate from RTEMS, and the application. The hardware +
bsp model.
> >I can raise a PR for this and list all the areas that need to be
> looked at.
> >I have not looked at the POSIX implementation so far :-). Are keys
> >handled in one spot ?
> As much as anything in RTEMS... see cpukit/posix/src/key*.c. The
> problem is that there is no event/API hook when the number of
> tasks/threads increases. Look at keycreate.c and you will see the
> problem.
Maybe I am missing something here. The keys are objects
(_POSIX_Keys_Allocate) so setting object info structure's auto_extend to
true will result in unlimited keys.
I do not understand the api loop.
Chris Johns, cjohns at cybertec.com.au
