the first called .c file ?
Ian Caddy
ianc at microsol.iinet.net.au
Fri Nov 8 05:11:40 UTC 2002
hi Howard,
This depends on your BSP that you are using.
For the M68K based BSPs (or at least for our one),
we start in a file called start.S in the start directory
It then calls init5307.c in the startup directory.
What you need to do is pick a BSP, then goto the start
directory, and look for the label start (or whatever your
reset vector is). Follow this code down to where it does a
branch or jump to and find the function that is called.
Then you just have to work your way out.
regards,
Ian Caddy
howard wrote:
> Hi.
> Which .c file is the first called during RTEMS up ?
> Thanks in advance!
> Howard
